Subject: Re: Bissework circle or arc not right if u goes pass the apperture of a circle
8/11/20
Billy Lobb
When a arc or circle if you pass the apperture (half circle) it dont read it right . Drawing in autocad but when it open in beisee work it not right . Hard to explain almost like it stop at widest point and just draw a line back to the other side. Could it be in the intergrate command. Thank
8/12/20       #2: Bissework circle or arc not right i ...
Dan
If you've drawn the arc as part of a polyline it should interpret properly. If you've drawn an arc as a segment on its own you may need to toggle direction (dir) and/or solution (sol) variables.
    • Country Saw and Knife
