Subject: Re: CNC BORING / ROUTING FEED VS SPEED
3/7/21
Tony John Member
PLEASE SUGGEST FEED AND SPEED FOR
18 MM EGGER CHIPBOARD BORING / ROUTING.
I USE HOMAG BHX 200 OPTIMAT.
ROUTING - RPM 18000 - DEPTH OF CUT 9MM
PLEASE SUGGEST FEED FOR 6 MM , 8MM , 10MM , 12MM DIA SPIRAL CARBIDE BIT.
DRILLING - RPM 6000 -
PLEASE SUGGEST 5MM , 8MM , 10MM , 15MM , 20MM , 35MM DIA BORING BIT FEED.
FOR VERTICAL AND HORIZONTAL BORING CAN I USE SAME FEED .
PLEASE SUGGEST. THANK YOU
View higher quality, full size image (1440 X 2560)
3/10/21       #4: CNC BORING / ROUTING FEED VS SPEED ...
Seems from the attachments that you have all the info you need.
3/11/21       #5: CNC BORING / ROUTING FEED VS SPEED ...
Stephen Williams Sponsor - Parts Cutter CNC
Website: http://www.partscuttercnc.com
Go to the back of the book.
    • Machinery Associates
