Subject: Re: Feedrate on Toolchange too fast, Biesse Rover
3/31/22
big chingus
Does anyone have issues with tool changes on Biesse Rover A or similar machine on the revolving tool changer magazine? When taking tools out and putting them back its a very janky movement and you can feel a slight rumble, its also inconsistent, sometimes not very noticeable.
Ive found that if if I slow the feed down on the override its much smoother. 2 other rovers in the shop don't have that issue.
I'm thinking if I was able to limit the feed rate on tool changes it would fix the issue.
Does anyone know of such a parameter or if that's even possible to change?
4/1/22       #2: Feedrate on Toolchange too fast, Bi ...
Don't know that machine at all but I have 2 Biesse's a Komo and an ANDI, and have had tool change issues with all of them. Not saying they are bad machines, they just have a lot of miles on them.
Make sure all linear slides and clean and lubricated.
Any pneumatic cylinders involved will likely have flow controls to allow speed adjustment.
Make sure all proxy sensors are securely mounted. We chased an intermittent issue for 2 days and it was a loose proxy.
We have found that videoing a problem and playing back at slow speed shows up a lot of issues.
4/1/22       #3: Feedrate on Toolchange too fast, Bi ...
cabinetmaker Member
we got the hell out of the banging, etc through weekly cleaning and coating the the tool holders with Lusin, and greasing the metaflux paste weekly also
we don't miss a pm
I sure as hell don't miss timing out and down time, beating the hell out of the tools to release one
down to one Rover thanks god
4/1/22       #4: Feedrate on Toolchange too fast, Bi ...
What Lusin product do you use and how? Never heard of it.
4/4/22       #5: Feedrate on Toolchange too fast, Bi ...
JKL Machinery
Website: http://www.jklmachinery.com
Lusin lube is draw bar lubricant. Tool holders should be coated with PTFE to prevent "sticking" in the spindle
4/5/22       #6: Feedrate on Toolchange too fast, Bi ...
Christian
Biesse recommend Lusin g31 protect for tool holders as per user manual
And meta flux paste for hsd draw bar lubrication
https://www.cnc-tool.com/store/p547/Lusin_Protect_G_31_SprayPart_%23_G31.html#/
4/9/22       #7: Feedrate on Toolchange too fast, Bi ...
cabinetmaker
Yep use what Biesse recommends
When we ran out of lusin we used the ptfe off the shelf from big orange Clean the tool holders spray. Let dry and buff off.
Keep it on a schedule enjoy the machine running
4/21/22       #8: Feedrate on Toolchange too fast, Bi ...
Mark Tomlin
As the machine ages and accrues thousands of tool changes, "slop" starts to show up and present in different ways. Sometimes you will have to replace parts to correct, other times you can buy time by slowing the tool change feed rates down in the machine data ( essentially what your doing now with the override , but allowing the control to control it so you dont have to) There are limits to how much you can reduce depending on may factors. To much and you can time out the tool change.
Mark
4/25/22       #9: Feedrate on Toolchange too fast, Bi ...
Acctek  Member
Start to change the speed of the tool, the speed between the workpiece and the tool
    • Machinery Associates
