Subject: Re: Powermatic 2x4 CNC Router
2/6/23
Jay Stafford Member
I recently purchased a Powermatic 2x4 with the Aspire11.5 software. I can preview all the toolpaths/ router speed etc... in aspire on computer, But when I download to a flash drive and install it into the hand held it doesn't turn on the spindle when it goes down to cut. Looked at G code on handheld and it doesn't show the router coming but shows the cutting on computer.
Any ideas? .
2/6/23       #2: Powermatic 2x4 CNC Router ...
You need an inverter call and a speed. Typically M3(CW rotation) and S16000 for 16000 rpm for example.That will turn on the spindle. M5 will stop the spindle when you are done.
2/6/23       #3: Powermatic 2x4 CNC Router ...
Ask these questions on the vectric forum. You will have a better chance of getting detailed help with this. Make sure you are using the appropriate post processor for your machine.
2/7/23       #4: Powermatic 2x4 CNC Router ...
That machine is just a branded product in the Powermatic line, but as mentioned, call Vectric or use their forum. Probably a list of FAQ questions somewhere on the internet.
2/7/23       #5: Powermatic 2x4 CNC Router ...
A link to aspire support
https://support.aspireapp.com/faq
3/20/23       #6: Powermatic 2x4 CNC Router ...
Matthew Rogers Member
You may want to make sure your voltages are correct. I found an interesting situation where my wild leg voltage from a 3 phase converter was just high enough to cause the Delta VFD to not turn on the spindle when starting a program, but also not throw any error codes. Controller (LNC - not Powermatic) showed spindle turn on, VFD showed frequency ramp up. My voltage is balanced pretty well with any load, but at full no load conditions, the wild leg voltage is 264v and for some reason the Delta VFD just lets it sneak through, but also doesn't at the same time. Kinda weird.
    • Country Saw and Knife
    • Template Services
