Subject: Re: Biesse Works
Biesse Works
6/1/23
Roger Forst  Member
Need help with Biesse Editor software. When importing a DXF file from Autocad is there a way to select multiple lines to make changes to the properties all of them at once.
Example: I need to adjust the Lead IN/OUT on multiple mortices but right now I have to adjust each one (approx. 200) individually.
Please help if you can. I can't find any online resources to help and the manual has no information.
Thank you
6/6/23       #2: Biesse Works ...
dylan bayliss
Website: http://www.machineconsult.com
it would be best to do that on the layer in the dxf, you can call out those commands on the layer name and it will come in automatically.
send me your email and I will send u doc on example
regards
db
6/9/23       #3: Biesse Works ...
Jason Scott
You can set the default setting you want to use before you import your geometry.
You can also use a find a replace on the VB code.
If you need help with that you can reach out to me.
    • Machinery Associates
