Subject: Re: Outline cuts with 1/8" dia.bits
11/14/23
Luke  Member
Website: http://segalebros.com/
We use 1/8" bits with our Biesse Rover A machine frequently. reasons to use 1/8" bits is for squaring corners and for outline cuts with grain matching.
In the past this has worked well but something unknown has changed. we keep breaking bits but in the past we didn't have this problem. we are cutting in 3 passes - 1/4" depth each pass - and slowed the tool to 300 inches per minute. yet the problem persists.
could this be a material issue? like MDF core vs. particle board core melamine? what other solutions should we try to make this work?
thanks! Luke @
Segale Bros. Wood Products
11/14/23       #2: Outline cuts with 1/8" dia.bit ...
Not enough information
Upcut? Downcut? Ramp? Plunge? RPM?
11/14/23       #3: Outline cuts with 1/8" dia.bit ...
Luke  Member
additional information: downcut, plunge cut and 18000 rpm
11/14/23       #4: Outline cuts with 1/8" dia.bit ...
We used to cut 1/8 slots 20mm deep in baltic birch.
Can you use an upcut? A downspiral packs the chips into the bottom of the groove. I've broken many bits that way.
Plunging a down spiral is also asking for trouble for the same reason. Ramp is best.
I think MDF will be worse than PB.
I'd use 1/8 pass - slow but better than breaking a bit.
11/14/23       #5: Outline cuts with 1/8" dia.bit ...
BH Davis  Member
Things that come to mind.
What about the bits? Different source, manufacturer etc.?
What about the machine? Any changes? How old? Worn x,y or z axis components? Any unintended movement at all would brake a 1/8" bit.
11/16/23       #6: Outline cuts with 1/8" dia.bit ...
When was the last time the collets were changed?
11/16/23       #7: Outline cuts with 1/8" dia.bit ...
jerry Member
What Chuck said collet to much run out
9/26/24       #8: Outline cuts with 1/8" dia.bit ...
Brendol  Member
Website: https://www.houzz.com/pro/brendol-scholz/creative-...
We had the same problem with the 1/8 upcut and downcut for grain matching. Worked great for one year then bits breaking. Trammed the machine, changed collets, still happened. Would like to know the solution.
    • Country Saw and Knife
