Subject: Re: Morbidelli x200
Morbidelli x200
5/14/21
Cody Member
I've seen some stuff on cutting melamine, I was wondering what tools you guys have found to be best for cutting it and the speeds and feeds that work best for those tools?
5/15/21       #2: Morbidelli x200 ...
Salce Smith  Member
For melamine board cutting, here is some suggests: for melamine chipboard cutting, suggest the T011 bit, spindle rotation speed should at 18000rpm-24000rpm. Feed rate could be 10-15 meters/min. For melamine MDF board cutting, suggest the T008 bit, spindle rotation speed should at 18000rpm-24000rpm. Feed rate could be 10-18 meters/min. For melamine plywood board cutting, suggest the T007 bit, spindle rotation speed should at 18000rpm-24000rpm. Feed rate could be 10-18 meters/min
Rico Router Bits for Melamine
5/16/21       #3: Morbidelli x200 ...
That seems a tad slow. I use a 3/8" 3 flute mortise compression tool running 18000rpm at 1000ipm or just north of 25M per minute with good life.
5/18/21       #4: Morbidelli x200 ...
Chris
Leuco coated 3/8 comp 18k can cut at 20-25 meters per min. But to take advantage of the x200 cutting capacity you will want diamond tooling. I’m not sure how far you can push a 3/8 diamond cutter but i know you can push a 1/2 spinning at 24k to 50 meters per minute.
5/19/21       #5: Morbidelli x200 ...
Cody Member
Thanks guys, I usually work with metal but I got this new job working with wood and they want me to code it and everything so I wasn't 100% sure on what tools people have used on wood before.
5/19/21       #6: Morbidelli x200 ...
Christian Livingston  Member
Send me a dm and I will send over a material chip load chart to help
Christian L.
4/3/24       #8: Morbidelli x200 ...
True Installation LLC.
How can i maximize the waste being sucked in by the vacuum during cuts? Since cleaning out the vacuum bags and hoses the cnc vacuum isnt working as effective as i need it to. Is there anything i need to do or an adjustment i can make in the Maestro program?
CNC Morbidelli x200
    • Machinery Associates
