Subject: Re: CNC ROUTER Recommendation
12/20/24
Rex Member
I will be purchasing a cnc router in the next several weeks. I hope to reproduce several heirloom pieces of furniture from my great grandfather. A couple music cabinets make heavy use of scroll work panels. Without spending a fortune and being new to cnc, what brand machines would you recommend for around $1,000 to $2,000?
12/21/24       #2: CNC ROUTER Recommendation ...
Jim Anderson
Rex,
Your price point would reflect a hobby level router or a well used router at best and you would still need software. You may want to consider using the money to have someone with a professional machine produce the needed parts.
12/24/24       #3: CNC ROUTER Recommendation ...
BH Davis  Member
Just a heads up as to why you aren't getting replies to your CNC router inquiry.
Woodweb is a commercial woodworking site. People who hang around here typically have CNC routers in the $25,000 to $250,000 range. What you want is a toy by comparison.
I will tell you that for $1000 to $2000 you are talking a small table top hobbyist model. I'd be surprised if it were even as large as 24" x 24". But for brands you should look at X-carve and the import cheapos on Amazon and Ebay.
If you want more info from people with these table top CNC's I'd suggest you visit www.cnczone.com.
2/11/25       #4: CNC ROUTER Recommendation ...
Acctek  Member
Website: acctekcnc.com
I don't know the size of the furniture you want to make, but the CNC router worktable that costs $1,000 to $2,000 is very small, usually 400*400mm, or 600*400mm, which may not be enough for cutting and engraving large-sized plates.
    • Machinery Associates
