Subject: Re: Cosmec Conquest 250 RTC Module failure
5/22/25
Lee Roberson Member
Website: http://restorationstationok.com
So, an alarm message I'd never seen before directed me to the battery that retains the CMOS info when the machine is powered down. I've replaced it with an exact replacement and the machine is essentially back up; but not running. Does anyone know specifically what info might need to be reentered manually or otherwise and the necessary steps to do so? I've become aware of CMOS setup (cylinders, heads ,sectors,precomp and landing zone), but don't really know how to proceed with that. I've also randomly received EE001 "Servo Error Axis(X,Y or Z)" message leading me to believe some physical machine parameters may also have been lost. Any info would be greatly appreciated. Thanks.
5/22/25       #2: Cosmec Conquest 250 RTC Module fail ...
What control?
Likely needs a full restore from backup.
5/23/25       #3: Cosmec Conquest 250 RTC Module fail ...
Lee Roberson Member
It's an OSAI 10 Series Control, Fujitsu MHH2048AT hard drive.
5/23/25       #4: Cosmec Conquest 250 RTC Module fail ...
Had this happen on a Biesse Arrow with the same control. Someone was nice and had loaded the files in a random spot so we were able to restore.
There is an OASI office in New England somewhere. Maybe their tech support can help you look.
5/23/25       #5: Cosmec Conquest 250 RTC Module fail ...
Jim Acconcio
OSAI-USA LLC
Electronics company in East Windsor, Connecticut
7/20/25       #6: Cosmec Conquest 250 RTC Module fail ...
ZeroBacklash Member
Were you able to get back up and running? I am curious as to what avenue did you take after the error...
    • Country Saw and Knife
