Subject: Re: Layered DXF
Layered DXF
1/30/26
Michael Jenkins
I've recently been having a shop cut parts for me on their CNC. It appears their subscription to WoodWOP does not include the feature to import layered DXF files and automate the toolpath process. This is a feature that I would really like to find in a shop in order to reduce translation errors and avoid confusion. I've reached out to 2 other shops locally that are in the business of cutting parts and neither have the capability with their system to import layered DXF files. Which brings me to my question - am I looking for a needle in a haystack here? Are there shops that do this?
2/1/26       #2: Layered DXF ...
I've tended to stay away from any of the machines that run WoodWOP so I am unfamiliar with their dxf import protocols. What is in the layers? Z depth, Tool number, or better yet, tool diameter, left/right direction as well as CW/CCW direction? We use Microvellum for some stuff. Its AutoCAD output layers have depth, direction, tool #, but not diameter. That infomation is sent to a dedicated post processor. That post handles feeds, speeds, and diameters associated with that particular tool called in the layer. What you are expecting a shop to do with just a simple layer format may be a bit much for any shop to handle without questions or possible error. Layer names are important for G-Code, or in your case MPR output, but that is not enough iformation to cut parts successfully 100% of the time.
2/1/26       #3: Layered DXF ...
Michael Jenkins
I'm only familiar with the 2 machines I've owned. When digging into WoodWOP I found documentation that with the professional version you can create template files and MACROS that map to DXF layers. Then all you need to do is open the Template file, load the DXF and WoodWOP creates the toolpath. Verify on the screen and run. With the basic version, the operator has to import the file and manually assign all that toolpath info, which is prone to error.
I'm not married to WoodWOP, it just happens to be the system the 2 shops I'm currently using to cut parts have. I'm open to any system that can import a layered DXF file. Not that I have a ton of volume, but enough that it really would make a big difference if I could just hand a shop a file and not expect them to have to manually assign everything. Automation is always a win-win proposition.
2/2/26       #4: Layered DXF ...
John Member
Website: http://www.stilesmachinery.com
woodWOP also comes equipped with a DXF importer tool, that allows a user to import a DXF (other import file types also available using additional woodWOP modules) file. If the DXF file has had the correct layer nomenclature added, woodWOP will automatically create the tool paths / operations without further requirements. There are two levels of this DXF import tool, the Basic and Professional version.
Within AutoCAD, all that is required to make this function correctly is to either create a Template with layer specific nomenclature or use an existing one. The primary benefit to the Professional version is to speed the process of batch files and to give more options in the layer naming prior to import.
For those companies who do not have a CAD/CAM program or a design program, woodWOP has some powerful design and manufacturing tools included.
2/2/26       #5: Layered DXF ...
We're primarily a CNC job shop.
We will not accept files without either layered DXF or 3D DXF or STEP files.
Too many chances for error.
If we have to, we teach our clients how to add layers.
So no, you're not looking for a needle in a haystack.
2/3/26       #6: Layered DXF ...
Michael Jenkins
Thanks Dropout. That's the answer I was looking for. What system are you using?
2/3/26       #7: Layered DXF ...
Currently using AlphaCAM but have used SheetCAM in the past.
Will your design program create machine files?
2/3/26       #8: Layered DXF ...
Michael Jenkins
Well, I still have MasterCAM so I could. But I can't imagine any shop would want that. I think the appropriate hand-off point would be a layered DXF file that the shop would import, autogenerate machine code, and verify on screen before running.
2/3/26       #9: Layered DXF ...
If you get the machine setup from your shop you could create the file he needs to run. Just needs the proper post for MC.
Or buy a CNC :)
    • Machinery Associates
