Subject: Re: Changing a Spoilboard
4/13/26
Destiny F Member
Hello I recently cut through my spoilboard and I have been looking for information on how to change it specifically for a Biesse Rover S. I just was wondering if anyone had any information or videos on how to do this. The reason i have to change it is because the program I ran through the system was faulted and ended up cutting an entire program about 3/4 through my board. If someone can get back to me with any information it would be greatly appreciated.
4/13/26       #2: Changing a Spoilboard ...
I don't have one of those you are running. After buying one of their edgebanders, I was done with them. What I do is remove the factory face of the board, then flip it removing the facory face on the other side. Typically 0.01" each side. I also drill and counterbore so I can attach the boards to the grid table below. This helps because it you keep milling the face, it will want to curl. Thats about it. I wrote procedures for my operators, but its specific to the Northwoods they run. As a matter of practice, I remove 0.01" each time will mill. My typical thru cut is -0.005". That ensures a nice table at mill time. You sound new, so good luck and happy routing!
4/14/26       #3: Changing a Spoilboard ...
Destiny F Member
thank you for the well wishes!
4/14/26       #4: Changing a Spoilboard ...
dylan bayliss
please find below a doc
https://www.cnc-tool.com/uploads/1/0/3/3/103363/spoilboard_applications_tip
s_sb-2023.pdf
https://www.cnc-tool.com/technical-white-pages-cnc-part-fixturin
g.html#/
5/10/26       #5: Changing a Spoilboard ...
Derrek
It’s been a while but here’s some things we did on our rover s before we went to Anderson
RoverSspoilboardimprovementhttps://youtu.be/0Dl9GTweTSg
    • Country Saw and Knife
