Selexx PAL spindle tool clamp down sensor
5/18/16
Eccurr2 Member
I am having an issue with a Selexx Pal machine. It's a 2005 model with the FANUC controller. I am getting a #1 spindle tool clamp down sensor error. I can't physically see any sensors around the spindle. I also do not have a schematic on the assembly of this spindle. If anyone has encountered this issue and can provide any help it would be greatly appreciated. Thank you
5/20/16       #2: Selexx PAL spindle tool clamp down ...
JK
Sensors are internal , there is a plate on front of spindle that has to be removed for access to sensors
5/23/16       #3: Selexx PAL spindle tool clamp down ...
cabinetmaker
Look up the clamp down sensor via Google
And, I might add it may not be the sensor itself, but a timing out issue during a tool change because of the lubricating issue with the tool holders
