Drill & Dowel insert machine
1/10/17
Eric
We are looking to purchase a drill & dowel inset machine. We are looking at Biesse ELIX, SCM's OMAL HBD 1300, Gannomat index 130 logic, and a KOCH sprint ptp basic. I am just wondering if any of you have any experience with or issues with any of these machines. Any input would be great. Thanks
1/10/17       #2: Drill & Dowel insert machine ...
Nick
Have you considered A weeke at all? Only one I have experience on.
1/10/17       #3: Drill & Dowel insert machine ...
Matt Krig Member
Omal 1300 HBD hands down- you can also get the same machine with a Biesse sticker if you like. The main reason we chose this machine after years of research is the simplicity and consistency laser measuring system. It's as fool proof and consistent as you can get, especially for a custom shop. Support has been fantastic and their vertical drill is the best option to maintain redundancy should our CNC go down and we want to do all machining. It's a little slower than some of the barcode driven systems, or those for high flow of the same parts, but simple and reliable.
There's a lot more to consider as you look to dowel construction. Case clamp- $ location, floorspace, operators, part and box handling operations. Your boring block on the CNC will now need a spot for an 8mm bit. Part handling changes as well. Cut band bore is pretty standard and you'll have to decide how to organize parts and whatnot and make sure the right parts are doweled on the right side every time.
We are wrestling with doweling everything from the simplicity of round peg in round hole versus the speed of a true cabinetmaker making things like toes from material at the bench.
1/17/17       #4: Drill & Dowel insert machine ...
+1 Omal
1/18/17       #5: Drill & Dowel insert machine ...
Dan
Omal 1300 HBD, 4+ yrs and only a couple minor hiccups. We do, I would guess, around 80K-100K dowels a year.
2/28/17       #6: Drill & Dowel insert machine ...
Kevin Member
Website: http://www.apdailey.com
We recently put our OMAL out to pasture. The machine was in service about 10 years with fair reliability. The PC required 3 power supply changes and the software could not manage well if a device was plugged in differently than original. The operation when working was good. The dowel pivoting mechanism was the thing that made it necessary to replace it. The dowels would not align to the sensor cleanly. We replaced it with a Weeke. This unit has a different dowel insertion system. I like it. The machine is solid!
