Re: inlaying plastic laminate into tables with wood edges and the offset
1/18/17
Brian
So you're cutting a pocket for the laminate to set in?
If that's the case I would get out the micrometer and depth gauge set. I have done this, took a little time to run a few test parts to dial it in. I would not want to do a very big surface like a table top, I would add a wood edge to a laminated substrate.
