Dadoes & rebates on various materials
2/1/17
Jack  Member
I'd like to know what router bits your using to make dadoes and rebates.
I cut a variety of material like melamine faced chipboard, melamine faced MDF, baltic birch plywood, standard MDF, moisture resistance MDF and Fire retardant MDF.
Generally my dadoes are 3mm or 6mm deep and my rebates can range from 3mm to 12mm.
I find standard 2 flute TCT cutters are fine for MDF but wear out relativly fast leaving chips in melamine face MDF. They also seem to leave a lot of tear-out on BB plywood going across the grain even when they are sharp.
I don't have much experience using down cutter so maybe they are the answer.
2/1/17       #2: Dadoes & rebates on various mat ...
I typically use a down spiral bit for rabbets and dados. You can also use a mortise compression tool if the up shear portion of the tools is below the face of the material. If getting a lot of tear out on birch ply, try climb cutting if the bit switch does not cure that.
2/10/17       #3: Dadoes & rebates on various mat ...
Jack  Member
Thanks Mike,
I've picked up a 2 flute spiral downcut, 3/8" (9.53mm) DIA, 7/8" (22mm) Lengthen of cut.
I can't find much information for speeds & feeds with this cutter on plywood, any suggestions?
2/10/17       #4: Dadoes & rebates on various mat ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
This guide gives you the answer.
Guide
2/10/17       #5: Dadoes & rebates on various mat ...
Pdub
That guide will give what you need if you got the Vortex bit. If you bought another brand, the geometry could be completely different, hence giving you a different chipload and then that chart would be off.
If you can't get the info from the manuf. of your bit, start with this chart and see how it goes. The bit should be warm, but not untouchable even after making a lot of cuts.
Even when I buy Vortex bits, I call and get the CL for the specific bit I bought. That chart is very general.
