scm supertech 100 cnc router
2/8/17
geoffrey grice Member
I bought a used cnc router. I am experienced at programing cnc for metal machines. I have figured out how to program a drill program. I cannot figure out how to program the horizontal drills or the 4 head routers anyone know this machine?
2/9/17       #2: scm supertech 100 cnc router ...
You might want to post what control software/control it uses. The SCM machines I used to work with were pretty simple to program.
2/9/17       #3: scm supertech 100 cnc router ...
it has a morbidelli control. I have a manuel but it does not tell how to program the horizontal drill and routers
2/9/17       #4: scm supertech 100 cnc router ...
Ok, it is probably a tria or xylog interface then. If I recall(been 15 years or so) F1 is defult face. F2, F3, F4, and F5 are the rectangular edges that need to be called on a block first to make them active. I believe F3 is the right face. Like any drilling, B starts the command for drilling. X is the location from the bottom of the panel. If you want to drill in the center of the panel of a 19mm thick panel 100mm in the y axis and 10mm deep it would be
B X9.5 Y100 Z10 followed by the drill # of the horizontal. On my old machine, I think 59. Works the same way on F2 which I believe is the left face. On F4 and F5, the front and back side of the panel, the X axis is the X axis, the Y axis becomes the distance from the bottom of the panel to the drill center and the z axis is the depth. Play around with it, you will see from the graphics help if it is ok. It has been a very long time, but I think I have the basics right. Call the face, then bore the hole with the appropriate drill # and you are good to go. Once you figure out the format, it is a very easy machine to write programs for on the fly.
