Wilsonart small parts cutting
2/23/17
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I'd like to cut a nest of small parts (6 in x 10 in) out of Wilsonart solid surface material. I have a Weeke Vantage 31S . Is this material prone to moving? Also would I need different cutters or are my carbide cutters fine? This is a side project for a guy that wants them cut. The Wilsonart material is similar to Corian. It would be in a 30 x 96 sheet.
2/23/17       #2: Wilsonart small parts cutting ...
Jared
You'd want the proper bit for sure. I use a downshear o-flute Onsrud 63-626 when cutting plastics. Skin cut the parts at the proper feed & speed for the thickness of your material and bit size, and turn off your air blast if your machine has one to avoid lift. You should be ok.
2/23/17       #3: Wilsonart small parts cutting ...
Gary Balcom
Nick,
Do you mean Wilsonart Compact Laminate? If so, that is phonelic, and much harder than corian. I use a 3 flute upshear with chipbreakers on compact.
4/22/17       #4: Wilsonart small parts cutting ...
George  Member
Website: http://www.allstaradhesives.com/
We helped a company in the Seattle, WA cut S T A R B U C K S lettering (from Corian in Green Marble, what else?) and had no issues with vibration or movement. They did not drop a single letter. And they did all in a single pass.
Let me know if I can answer any questions for you
401 247 1866
