HSD replacement shafts
4/21/17
Wood Dust
Where do you buy these ? I just got a quote from my machine manufacturer and they want $9,200 for just the part . My machine is only 3 years old and this is my second shaft , the first one was under warranty . I keep my machine clean , and do the proper maintenance.
Any help would be great please
4/22/17       #2: HSD replacement shafts ...
Jim
Website: http://totalcutcnc.com
HSD USA Inc.
3764 SW 30 Avenue
33312 - Fort Lauderdale, FL (USA)
Tel: +1 954 587 1991
Fax: +1 954 587 8338
web: www.hsdusa.com
http://www.hsdusa.com
4/22/17       #3: HSD replacement shafts ...
mike
if u have replaced any in that time frame you have to have another major problem causing it. but here u go
http://www.cncpd.com/product/hsd-shaft-kit-a6391h0073b/
4/22/17       #4: HSD replacement shafts ...
I am on my second HSD spindle cartridge on a machine that was new in 2003. Something is wrong here. Usually it is programming. Do you warm up your spindle everyday? I have a warmup program that starts with a low rpm and gradually ramps up to full speed over the course of 5 minutes or so. Also cycle all the drills during this program to make sure none are sticking or need attention.
4/22/17       #5: HSD replacement shafts ...
Wood Dust
It's been my fingers on the cartridge both times , I clean them every week . I clean my tool holders every week and lubricate the spindle with the suggested meta flux also . It's so frustrating.
4/23/17       #6: HSD replacement shafts ...
Jim
Inspect your tool changer, it sounds like a misalignment causing your tools not to pick up properly and damaging the fingers.
4/23/17       #7: HSD replacement shafts ...
Maurice Phelps Member
So question when the 1st shaft was replaced what did the MFG say was the the cause of failure or did they say?
Also this is the shaft that failed not the gripper fingers, correct.
4/24/17       #8: HSD replacement shafts ...
B.H. Davis Member
The folks at HSD in Hollywood, FL are always helpful on the phone. I'd call and speak with them if you haven't already done so.
In terms of trying to find the cause of the problem I too would look at the tool pickup routines. Look closely at alignments when the tool is being picked up and see if there is any angular, sideways, forward back etc. pressure on the tool when it is being grabbed.
The only other thing I can think of to check is the squareness of the spindle to the work surface. While this would be more of a concern for premature bearing wear I'd want to know that bits are precisely vertical when any problem is occurring.
4/25/17       #9: HSD replacement shafts ...
Wood Dust
Thanks guys, great suggestions. Unfortunately still not resolved.
Maurice, yes it is just the fingers not the whole spindle that is the problem. I am waiting to hear if I can just replace or repair the fingers.
4/26/17       #10: HSD replacement shafts ...
Give Ryan a call at All About Spindles, he has a extensive amount of experience on both the repair and the application side of various types of spindle. I asked him if the fingers alone can be replaced, he has indicated Yes...they can be.
Ryan
All About Spindles
(678) 900-1058
www.allaboutspindles.com
4/26/17       #11: HSD replacement shafts ...
Wood Dust
Thanks guys, I reached out to a local woodworking shop that has had cnc's for years and they were happy to talk to me and had a very similar problem 3 weeks ago by chance. They walked me through what they did to fix it, took the fingers and draw bar apart and reset them . So far we are back up and running. Its nice to know we can lean on each other during frustrating times.
5/4/17       #12: HSD replacement shafts ...
Will Williamson  Member
The replacement spindle for my 10 horse HSD on my thermwood only cost 4500 dollars from Thermwood.
