drilling stacked 1/4" MDF
5/5/17
John Earp
Website: http://mountainhomecabinetcompany.com
Quoting drilling pegboard holes in MDF.
What problems might I face if I stacked them 3 high?
5/5/17       #2: drilling stacked 1/4" MDF ...
They'll move.
Use plastic pins (raptor) at the corners.
5/7/17       #3: drilling stacked 1/4" MDF ...
John Earp
Website: http://mountainhome cabinetcompany
Where do I find Raptor?
5/7/17       #4: drilling stacked 1/4" MDF ...
Brad
http://raptornails.com/
5/8/17       #5: drilling stacked 1/4" MDF ...
B.H. Davis Member
Assuming this is thin MDF you should also use a downcut spiral router bit. An upcut spiral bit would pull each sheet upward as it plunges and end up spreading dust between the layers resulting in chip out at the hole edges.
5/8/17       #6: drilling stacked 1/4" MDF ...
Jerry Member
Depending on the thickness and how much vacuum you have not much. When we move MDF with our vacuum lift it will pick up 2 sheets of .75 MDF
5/8/17       #7: drilling stacked 1/4" MDF ...
John Earp
Thanks for all the information!
John
5/10/17       #8: drilling stacked 1/4" MDF ...
Kevin Jenness
I would be very wary of using a downcut bit for drilling to any depth, as I have heard of fires starting that way.
5/10/17       #9: drilling stacked 1/4" MDF ...
B.H. Davis Member
Kevin,
That's a great point on fire potential on a down cut spiral drilling procedure. With a fast plunge and 3 layers of 1/4"thick MDF I would think it should be alright. However if there aren't too many holes then a safe alternative procedure would be tdo the full depth in 2 plunges about 3/8" each. While some dust will remain in the hole it the shallow depths per pass should further alleviate the potential for fire.
Thanks for bringing that up. It's something I should have touched on in my earlier post.
5/15/17       #10: drilling stacked 1/4" MDF ...
Marty Member
G'day,
You can put a thin sealed spoil board on top.
It will hold down, and you can then use an up cut.
Works a treat.
Cheers Marty
6/5/17       #11: drilling stacked 1/4" MDF ...
David B
Website: http://beaconcustomwoodwork.com
If you can rout the hole with a slightly smaller diameter bit using a spiral plunge instead of drilling with a straight plunge you might get better results and less likelihood of burning
