SAW FEED AND RPM IN BIESSE
5/28/17
ANTONY JOHN Member
LAMA 120 SAW FEED AND RPM IN BIESSE. PLEASE LET ME KNOW THE OPTIMUM FEED AND RPM FOR GROVING MDF AND CHIP BOARD.
IF I USE CLASS MANAGEMENT, FEED VERY LOW. CAN I INCREASE IT.
PLEASE HELP , THANK YOU
5/30/17       #2: SAW FEED AND RPM IN BIESSE ...
Chris Rooker  Member
Antony, use one of the chipload calculators. I don't recall how many teeth the 120mm blade has, but if you are using the saw on the drill block it typically runs at 4000 rpm. But you will have to take your other variables into consideration. Or, start slow and speed up until you like the sound of it and cut quality. Push it until you feel you have reached the sweet spot.
5/30/17       #3: SAW FEED AND RPM IN BIESSE ...
Mark T
If this is the dedicated saw unit on the boring unit, and depending on the age/generation of the machine - the RPM is fixed at 4000rpm as a function of the boring unit motor.
The intent of that specific saw unit is to cut kerfs for backs, so it is presumed the cuts would be relatively shallow. That said you would want the plunge feed at around 1~2meters per minute (1000~2000mm per min) and the traverse feed at 6~8 meters per minute (6000 ~8000 mm per minute).
Hope this helps
Mark T
