Benz vs Techniks
5/30/17
Ron Jones  Member
Website: http://www.rjoneswoodworks.com
So I am looking at adding an aggregate and C axis to my CNC and it appears that the Benz and Techniks are the most prominent heads out there anyone have any comments either way?
I have a 12Hp HSD ES 929 and was curious is there anything that needs to be retrofitted on the spindle to make this happen? I will have to build a new dust hood, no biggie but other than posts, software, and the controller requirements what really needs to happen to get this to happen?
5/31/17       #3: Benz vs Techniks ...
Wood Dust
I believe you need to have the actual c-axis installed . At least on my biesse it was a separate assembly. It's a mounting block and a small motor that hold the aggregate in place along with rotating it 360*.
I have a techniks duo. Works great for me , been solid for 3 years now .
I believe you are looking at a substantial investment to get the c-axis. Between the install of the c-axis ...your aggregate , and post and software upgrades I think your looking around 15k. I am no expert here , just wanted to share what I do know .
Good luck !
5/31/17       #4: Benz vs Techniks ...
Ron Jones  Member
Yes that is what I have come to learn, I need to have the servo added to the spindle, ughh Yes, it is a considerable investment however being a job shop it increases my capabilities immensely. So far between the agg and software I am at about 23k....
5/31/17       #5: Benz vs Techniks ...
Mike A
if you have a HSD spindle might be best to get a HSD aggregate? At IWF they had a catalog they had a huge catalog of options.
FWIW. I purchased a few benz aggregates at an auction and thought i got a great deal but found out they needed to be retro fit to my HSD spindle. They work now but in the end probably best off buying new.
5/31/17       #6: Benz vs Techniks ...
Ron Jones  Member
The HSD agg is a thought I may just have to look into however I have a buddy that is a Techniks dealer so I would essentially be getting that at cost:)
5/31/17       #7: Benz vs Techniks ...
Ron,
I have used both Techniks and Benz aggregates and trained others on their use. At one shop, brand new out of the box both Techniks were defective and had to be returned due poor manufacturing. I had one at my shop break under warranty as well. To be fair, this was 7-8 years ago, not recently. My Benz units have held up a bit better but have experienced issues with them as well. Expect to have some repairs, even if none of the issues are from programmer or set up mistakes. BTW, most problems that aggregates have are due to poor programming or set ups. Watch the temperatures and don't be too aggressive with cuts and they will last a long time. Also ask about cycle times. Except for one, all of mine are oil bath which are rated constant duty. Good luck.
6/5/17       #8: Benz vs Techniks ...
Mike McClaran
Website: http://www.greenbvc.com
You can use the aggregate at 0, 90, 180 and 270 without installing a C axis.
Also with my 35 years in the business Benz is the way to go.
