Dowel insert Drill Bit
8/16/17
Gary Balcom Member
Website: http://www.Atlantacabinet.com
I'm looking for recommendations for a drill bit for our accusystems HPJ dowel inserter. It has an ER25 collet setup, so I can go 10mm, or 0.375" shank, but need an 8mm hole.
We've used 8mm brad points currently, but I'm wondering if something better is out there. I don't particularly like putting a D shank into a router collet.
Thanks for any feedback.
8/16/17       #2: Dowel insert Drill Bit ...
You can put a D shank into a router collet we did it for years with an accusystems machine. I agree its odd but it works. Line the fingers up to jump the flat spot. Vortex (and others I am sure) sell a solid carbide bit. They are expensive and hard to get sharpened. I would not go that route, brazed carbide works well.
A brazed bit is ~15 bucks and can be resharpened successfully. Change the bit often, don't wait till it starts to burn.
Good luck!
8/18/17       #3: Dowel insert Drill Bit ...
Gary Balcom Member
Thanks for the info Bill. We'll keep using the D Shank, as I can't even find an alternative.
8/21/17       #4: Dowel insert Drill Bit ...
Matt Krig Member
Will this work?
https://www.mscdirect.com/browse/tn/?searchterm=8mm+er25+collet&hdrsrh=true
8/21/17       #5: Dowel insert Drill Bit ...
Matt Krig Member
https://www.mscdirect.com/browse/tn/?searchterm=10mm+er25+collet&hdrsrh=true
8/21/17       #6: Dowel insert Drill Bit ...
Gary Balcom Member
Thanks for trying to help Matt, but I was looking for the actual bits, not a collet. It was great seeing you and the whole CMA crew in Vegas!
As an aside, I'm really enjoying the profiles magazine.
8/21/17       #7: Dowel insert Drill Bit ...
Matt Krig Member
Gary, great times in Vegas! I hope you'll be joining the gang next march in Denver for the 20 year summit, we'll have some great presenters and shop tours.
As far as the tooling goes, my understanding is the minimum order to get a production run of a new braze on type tool, is around 50 from some of the major manufacturers. If you committed to that quantity yourself, organized a buying group, or could demonstrate immediate demand, I'm sure CMT or Vortex would jump on it. It may not hurt to see who's making the tooling for Lockdowel or Fastenlink
We are in the same boat looking for metric tooling for doweling and other operations.
9/2/17       #8: Dowel insert Drill Bit ...
brian
Try This
https://www.toolstoday.com/p-6361-dowel-drillboring-bit-adapter-for-cnc-standard-c
ollettool-holder.aspx?&variantids=12535,0&keywords=47638
9/4/17       #9: Dowel insert Drill Bit ...
dustmaker1
I have used both ER32 and SK10 collets with D shank tooling on both wood and metal without problems, can't imagine not working fine with ER 25 also.
You may want to try solid carbide brad points though, we get a longer run time with those in our Omal.
Paul R
