s2m parts oversized off cnc
8/23/17
Eric Gravdal
we have a komo cnc, and are in the final stages of switching from cabinetware to vision. The issue i have run across is when i nest ware parts now the program wants to run one material at 180000 rpm and another material has my parts coming out 1/6" oversized. im stumped on what is going on and was wondering if anyone had any suggestions, thanks
8/24/17       #2: s2m parts oversized off cnc ...
Wooddust
For the pieces coming out 1/16 oversized , have you used a set of calipers to gauge the true thickness . It seems that the problem may be that the software is set for 3/4 but the material is actual .73 or so. This would throw you off .
Good luck
8/24/17       #3: s2m parts oversized off cnc ...
Jerry Member
When you say the parts are coming out 1/16 bigger did you check the true size of your bit and are you using a climb cut or conventional cut.
8/24/17       #4: s2m parts oversized off cnc ...
Eric Gravdal
The issue is in the length and width of the parts, we did mic the bit at 3/8 and its not a climb cut. im thinking its in s2m since it also wants to run another material at 180000 rpm rather than 18000, but both issues are material specific
8/24/17       #5: s2m parts oversized off cnc ...
mike
do u have correct post processor for visiin
speed problem sounds like post language
8/24/17       #6: s2m parts oversized off cnc ...
Could be a lot of things. Is it all parts, or just parts with edgebanding? Do the part sizes match the cutting bill? In the machine catalog, is the tool defined with the correct diameter? Sometimes metric conversions get people fouled up. Is Vision using cutter comp and applying it correctly and canceling it properly? Is there an unwanted number in the wear column of the tool radius at the machine? From my experience, check the obvious things first. If it still makes no sense, a little more info, please.
8/25/17       #7: s2m parts oversized off cnc ...
cabinetmaker
Make sure the room table is accurate in the post processor and the komo router.
The rpm and feed rate are a trial and error thing that we just ran code out to the machine and opened the posted job and looked at the feed rate and rpm sent.
We run particle board, corian, melamine and a lot of double sided plam. CV handles it all pretty well except the the post on drop edges-end caps for corian.
8/28/17       #8: s2m parts oversized off cnc ...
Eric Gravdal
It ended up being corrupt materials. We made a completely new material and ran it with no issues.
8/28/17       #9: s2m parts oversized off cnc ...
Paul S
Hum, both CW and CV should run on S2M ver.10 .....What version are you running ? I would like to continue to run both products for now.
