Mortise Compression Bits
9/20/17
JM
We typically buy our bits 10 at a time. Currently using NapGladu RS291. Its a 3/8" 2flute compression bit. 90% of cutting is 5/8 melamine or 5/8 MDF.
Occasionally it would be nice to have a mortise compression for some of our cuts. Not all the time, but once in a while. We usually just leave the regular bit in and deal with the little bit of chip out.
My question is, are there any drawbacks to using a mortise compression for everything? Seems to me there must be a reason they make both a regular compression and a mortise compression instead of just mortise compression, but I cant figure it out. Hoping someone can enlighten me.
9/20/17       #2: Mortise Compression Bits ...
B
Mortise compression can be used for dados of a depth greater than the length of the upcut portion of the bit. Mortise compression bits will leave the kerf packed with chips if cutting in a single pass since there is more of downcutting motion than upcutting, pushing chips down.
That's how I understand it, anyway..
9/20/17       #3: Mortise Compression Bits ...
JM
I did realize that the downcut would pack the kerf with dust, but other than that, was just curious if there were any other issues using them.
9/20/17       #4: Mortise Compression Bits ...
I have been using mortise comp 3/8" diameter bits for most of my 3/8"-3/4" mdf and particle board for quite a while. The neutral pressure point on the tool is a little low for the thicker material, but I only have 12 positions in my tool changer, so that was my compromise. We cut plastic, solid wood up to 2-1/2" thick, and everything in between, so I only have a few slots open for my everyday tools. The 3/8" mortise compression bit gets one of them. Try one for a little while and see how it works for you.
9/21/17       #5: Mortise Compression Bits ...
Chuck Hicks Member
Yes, if you have the ability to osculate your spindle or move up and down, you can spread the cutting out over more of the edge on a standard compression bit and extend the life.
