Convert DXF to PGM
11/4/17
Andreas
Hi everyone!
I have a huge problem.. I can´t use my dxf-files in my Morbidelli... And an expert told me that I need to convert the files to pgm-files. Does anyone know how I can convert the files från DXF to PGM? Which software?
Thank you in advance!
11/4/17       #2: Convert DXF to PGM ...
This might help:
http://www.cnczone.com/forums/general-off-topic-discussions/348480-softwa
re.html#post2112036
11/5/17       #3: Convert DXF to PGM ...
Benjamin
I use Enroute ATP for batch processing hundreds of DXF parts for kitchens peacemeal. The result is XXL files which I convert to ISO via a binary converter app. The app lets you choose PGM or ISO output.
If you are working on individual DXFs you manually apply the toolpaths and then output code to the machine.
11/11/17       #4: Convert DXF to PGM ...
keelhauled Member
DXF means drawing exchange file.
You wont be able to convert to .pgm without importing into your machines drawing programme and editing and assigning toolpaths.
From experience both Alphacam and Aspire readily accept .dxf files but I'm sure whatever you have will too.
