Vaccume Valves
12/14/17
Bob Member
Anyone know of any reasonably priced Actuated Vacuum Valves suitable for use on a CNC?
Under $100 is what I consider reasonably priced :-)
Electric 24V dc preferred but other voltages or pneumatic would work.
Needs to be close to 1 1/4"
The ones I have found have a very limited flow.
Bob
12/14/17       #2: Vaccume Valves ...
1 1/4 seems small...
I'd try ebay or alibaba or kijiji.
EBay link
12/15/17       #3: Vaccume Valves ...
Bob Member
That is the size I need.
It will work fine for the application I have.
I have tried those sorces.
12/15/17       #4: Vaccume Valves ...
Some plumbing valves are vacuum rated
Here is a large pool valve
https://www.jandy.com/en/products/valves/neverlube
That has an available actuator.
https://www.jandy.com/en/products/valves/valve-actuator
This has to be one of the more inexpensive ways to do it if the valves can handle vacuum.
12/15/17       #5: Vaccume Valves ...
I called Jandy, the engineer is not in today I am going to send an email to be evaluated monday by the engineer.
The valves are around $50 for that price I might just try it and see what happens.
I think a key would be to not actuate the valve with vacuum applied. In my application I think I could do that.
12/18/17       #6: Vaccume Valves ...
B.H. Davis Member
This may be an over simplistic solution but I think I've seen PVC pool valves used on vacuum tables. These are inexpensive and may indeed do the job. If you can't find them as small as 1 1/4" then you could just bush down a 2" version.
Do a search on "PVC pool valves" and a lot of choices will show up.
