Laguna iq spindle
1/10/18
Andy K. Member
Using Aspire 9.x. After initiating the program the spindle starts the program but does not lower onto the piece. It starts at full height and only lowers each pass. I've re-designed in Aspire, re-booted machine, and tried a different thumb drive. The spools remain greased and are not binding. The machine did sit for about a month or two without running.
1/11/18       #2: Laguna iq spindle ...
tom Member
Did the router work with any other version of Aspire.
1/11/18       #3: Laguna iq spindle ...
Maurice Member
What happens when you run a old program that did run successfully prior to the time the machine has been idle?
1/12/18       #4: Laguna iq spindle ...
I would compare the g code from the previous version and the current.
I'd suspect a post issue.
