1 piece MDF door
1/14/18
Cs
When I am making a door with a bevelled inside edge profile I can achieve a sharp corner by exiting the cut at a 45 degree angle in x and y and ramping out in z at the bevel angle. Can this technique be used for a filleted profile by ramping out in z on a radius that matches the fillet? I hope my question makes sense
1/14/18       #2: 1 piece MDF door ...
In theory, yes, but the software will need to know the radius of the tool. Not sure what software can do that.
1/15/18       #3: 1 piece MDF door ...
yaakov katz
no,cant
only option by smal radius tool 3mm to sharp the corner
we have such macro
in knest
1/17/18       #4: 1 piece MDF door ...
kolin
No it will not work. You will need a corner cleanout tool which is the same radius as your fillet cutter, but comes to a sharp point at the end. This allows your corner to look square at the base of the fillet. The top would need to be squared up with a different tool. As for the radius itself, I am not aware of how you would cleanly cut this square. With the top and bottom of the profile cut square you barely notice the radius. Hope this makes sense. Look at page 71 in the Vortex tool catalog. (see link) This may clear things up.
Vortex catalog
1/21/18       #5: 1 piece MDF door ...
katz Yaakov
hi
sorry for the late respone
knest is mine software ,its mainly create to import the parts from Polyboard ,nest,optimise, and make many opertaion to make work much easy
like cut order the parts ,calculate best entry point(to keep parts as posibole conect to main board)
and also rought Mdf doors directly from project included sharp corner in some method
if you want more details send me mail
ill send you some video
** knest can connect ANY type of cnc
included divied the working into 2 cnc
or auto labeling
View higher quality, full size image (1366 X 768)
