Anderson alum/phenolic grid sizing?
1/29/18
Steve Member
I've been tasked with making pods for our new Anderson CNC (which we don't actually have yet) on my Homag but all I'm told is the table is the same. I tend not to believe that.
Does anyone know the table grid of the Anderson CNCs? The Homag is 30mm of which 7mm is the gasket groove and the depth is also 7mm.
1/29/18       #2: Anderson alum/phenolic grid sizing? ...
DannyB
A lot of these grids actually are the same.
The spacing is usually 30mm as you mention.
My recollection, however, is that Anderson is slightly off (or at least, used to be).
Honestly, i'd just bug Anderson and ask.
2/7/18       #3: Anderson alum/phenolic grid sizing? ...
Mike McClaran
Steve,
You make the wood components and I will make the Better Vacuum Cups. You could have had these in your shop by now. Also Anderson is likely going to tell you to buy the Green ones. Call us, we can help.
877 872-2821
View larger image
2/7/18       #4: Anderson alum/phenolic grid sizing? ...
Chevy
im not sure how they make these pucks,,but i can vouch for better vacuum cups,,,used them on weeke and biesse,,and they are spot on,,,acutally better than the ones from Homag,,ive even cut thought a few of them,,keep up the great work,,
hooray for the hot girls at your events
Chev
2/8/18       #5: Anderson alum/phenolic grid sizing? ...
steve Member
I have looked into the green pods and many others but I find that a two piece pod with a changeable top (for damage and size) works best for what we do.
Turns out Anderson was supposed to match our Homag table exactly (for sharing pods) and failed to do so. They are close and small pods fit but the spacing is off just enough that longer pods are too tight to fit.
2/8/18       #6: Anderson alum/phenolic grid sizing? ...
Mike McClaran
Steve,
Perhaps you have not seen our video. While you are purchasing your rubber replaceable tops, our BVC is still running for free in 30 seconds by installing the foam gasket. It's pretty safe to say our BVC lasts 20 times longer than what you are using now. Just as Chevy said he has routed into a few and still using them.
Here at BVC we manufacture over 40 different sizes of vacuum cups. A picture says a thousand words. Maybe if we could see a picture of what you are trying to accomplish, I or someone else on the boards could help.
https://www.youtube.com/watch?v=Dw1IU2Pdyco
2/8/18       #7: Anderson alum/phenolic grid sizing? ...
steve Member
I've seen your video and an impressive product it is.
However if you are skilled enough to not hit your pods nor purchase your pods in the first place it is far more economical to make them yourself. I'm using the same pods I made when we started our new line five years ago and other than pitch build up they look and work as they did new.
2/9/18       #8: Anderson alum/phenolic grid sizing? ...
Tom Flowers
Website: http://AndersonAmerica.com
The Anderson Grid is on 50mm centers. It has a 5mm x 5mm groove pattern. BVC, Schmalz, and NEMI all make standard offerings for this grid. Email me if you'd like for me to send you the part #s.
Regards,
Tom Flowers
