Board cutting yield
2/19/18
anthony Member
Hi all
hope you are having a great day
I am interested in getting a flat table router so i can nest my own melamine sheets to make cabinet , furniture.....
But i am facing a small problem to understand how can a cnc router with a 12 mm bit go against a 4 mm blaid beam saw
will a beam saw give me more yield ??
thank you in advance
2/19/18       #2: Board cutting yield ...
Zak
Anthony,
Look at this patter (nest) and ask yourself if you could cut this on a saw without tearing your hair out.
Cheers!
View higher quality, full size image (498 X 305)
2/19/18       #3: Board cutting yield ...
The above times 15 to 20 sheets per kitchen times (just guessing) 2 kitchens per month.....
Plus all holes pre-drilled in exactly the right place every time.
Plus the work is being done while you are edgebanding or assembling or having a coffee....
2/21/18       #4: Board cutting yield ...
Anthony Member
Thank you for your reply
So using a cnc router will help me gain more yield than a beam saw
I am looking to convince new customer to start using my cnc service
2/21/18       #5: Board cutting yield ...
Most guys up here use a cost per sheet, say $25 to $30 per sheet.
Ask your prospective client if he can:
Unload the 4X8 sheets from the delivery
Store them
Lay out all the parts for least material usage
Cut them dead accurate and square
Drill all the holes perfectly
Dispose of all the waste
For $25 to $30 per sheet.
2/25/18       #6: Board cutting yield ...
Derrek
It goes both ways. The CNC does create 3 times the sawdust volume. It also creates certain yield issues, for example the beam saw can cut 4 wide x 4 long of an exact 12” x 24" shelves on a 4x8 sheet. On the CNC you can only get 3x3 of the same size. We adjusted our sizes to avoid that. As shown in the pic above, the nest can randomly place parts for the best yield regardless of size. We routinely run 10-15 sheet jobs and the first 14 sheets will have nothing but sawdust for waste and sheet 15 will have a 2x3’ piece of scrap.
Another thing is we found the beam saw created large batches of work, requires more operator input. The CNC gives us a better flow, the parts come off at an even pave and allow them to be edgebanded while the next sheet is running. We never have pallets of parts to move and run on a secondary machine. We also found we were rarely stacking multiple sheets due to a variety of part sizes.
