Parameteric programing
3/12/18
From a really old post:
Parametric programming is useful when used as an extension of the programmer. For instance, let’s say that you have arcs and straight lines in your program. It can be useful to control feed-rate based on formulas that calculate chip load in a turn verses chipload on a straight line move.
Instead of programming different feed-rates, it is possible to have the control calculate feed on the fly. At the top of the program there is a list of variables for feed and rpm. Make subprogram to calculate feed-rate based on size of arc. If move is straight then make feed a specific sfm (surface feed per min). Tool companies list formulas for their tools. Remember that imagination is the key. See it and then sketch your point of logic path you want to accomplish and finally program it.
Example; #100=85;sfm
#101=.005;chipload per tooth
#102=4;number of flutes
#103=.375;tool diameter
#104=(85*3.82/#103);rpm
#105=(#104*#101*#102);feed
This program becomes fun to the operator if he wants to experiment with tool life. Also these macros can be installed in posts to solve tool changer problems etc. I have even installed a macro in a post that automatically inserted tool comp and had a line of code that the operator could edit so he never had to go to his off-set page.
So, the question is, in a program that has lots of starts and stops, does it make sense to vary the RPM to keep the chipload constant or am I just chasing rainbows?
3/12/18       #2: Parameteric programing ...
Rainbows
3/12/18       #3: Parameteric programing ...
Jared Emery
That would freak my ears out. I have dad-ears that hear everything in the shop, when a machine is out of whack. Varying CNC RPMs would take some getting used to for sure. On a more pragmatic note, I've noticed my own tool wear comes less from uniform wear from chip load and more from non-uniform wear (plywood glue lines and p-lam).
3/13/18       #4: Parameteric programing ...
Mark
On my machine correct chip load is nearly never actually achieved. If it takes 12 inches of accelerating to hit 720 inches per minute no portion of any drawer part is cut at the correct chip load, and only a small amount of a cabinet side is cut at correct chip load.
Take the situation to it's logical conclusion and at every corner the machine comes to a near stop, meaning that the spindle speed would have to be very low at that point, 4 times for most parts and then a much higher as the feed rate comes up.
If one could design the perfect spindle it would be able to handle that kind of variable RPM and load. In real life, it would wreak havoc on the bearings and although I do not have sufficient depth of knowledge to say with certainty I do know that my spindle does not have much torque at very low RPM, and it may not be able to cut well at the corners.
Maybe it's rainbows in the real world but I think your logic is perfectly sound if the hardware could keep up. There may be a "middle of the road" that varies the rpm in relation to the feed rate that keeps the spindle within design parameters and the chip load closer to "correct" .
