Spoilboard question
12/22/18
Ag Member
Hi all i have a question
I use an 18 mm mdf as spoilboard and reserface it as when needed its the first time i get to a 10mm thikness and i am starting to have problem when i need to work with only small pieces i have a 4m *2.2m homag cnc i have 4 area i work with one and cover most of the unused space
Still i have some problem
Should i get a new spoilboard?
Or i put a 12 mm over it?
Thank u
12/23/18       #2: Spoilboard question ...
jerry Member
When my spoil board gets down I just replace it. I do glue mine down so I just fly cut it off.
5/29/19       #3: Spoilboard question ...
Travis Hanley Member
At 10mm you get a lot of loss because the vacuum is pulling to freely where you have routed. Best to replace around 12mm.
If you fave had deep rout pass it have used bondo to repair prior to fly cutting the surface.
