Fixed shleves for cabinet
2/10/19
Anthony Member
Hi all hope ur having a great day
I own a cnc flat table and i nest all my cabinet on it i do frameless cabinet with laminated chipboard
I would like like to get ur oppinion on what u use to fix ur fixed shelves?
2/10/19       #2: Fixed shleves for cabinet ...
Dowel construction, 8mm.
2/10/19       #3: Fixed shleves for cabinet ...
Or blind dado.
2/12/19       #4: Fixed shleves for cabinet ...
Dan
For fixed shelves we have done things a few different ways.
Drop On Cam and Screw In Dowel - such as Titus in the link below.
-The advantages are for cnc flat table, all the machining is in the face of the parts, no edge boring or second side machining. Holes for screw in dowel is machined in cabinet side which sets the placement of the shelf. The shelf is machined for the knock in fitting. Fixed shelf can be placed at anytime during assembly and can easily replaced if needed.
-Disadvantage: Fitting in shelf is visible.
Blind Dado:
-Advantage: Side is machined for shelf placement.
Pocket Screw: Shelf is cut to size and use pocket screws to fasten shelf to side.
-Advantage: Quick
-Disadvantage: Requires assembler to properly place shelf.
Titus or Similar
