Issue with grabing values in Biesseworks
7/29/19
Howard
Hello Gents,
I am new to biesseworks and looking for someone can help me how to grab values from a geometry.
If I have a rectangle, I would like to grab its length or height. Can someone tell me how to do it? I want to store the value in program variables.
I also want to grab/store the values between program variables and vbscript.
Can someone give me an example?
Thank you
Howard Y.
7/30/19       #2: Issue with grabing values in Biesse ...
Dan
I don't have the best VB skills but we do use it for controlling some variables. We need to know the value of something or test for a value.
Simplest example- Like making a cut:
If LPX<=800 Then (Test)
LE1=200 (Set Variable)
Else
LE1=250 (reset variable)
End if
LE1 will be the variable used for a milling line length and initially set to 150. When the piece size LPX is changed to anything over 800, the value will reset at 250.
That set of instructions can be as complex as you want to make it but it relies on testing for a value and changing a variable based on the result.
I don't know if you're importing or creating geometry in BW and can't imagine what you're trying to achieve so it's hard to advise as to the best approach but we do tend to drive geometry with variables that use a known value.
8/6/19       #3: Issue with grabing values in Biesse ...
Howard
Thank you Dan.
I think I know how to do it now.
Instead of throwing the value back to program variables, I can just do my cut in VB script.
I have more issues to ask if anyone can help me on them.
1. How to grab the width/length from a geometry?
2. How to grab a tool diameter from tool?
3. If I create an arc with 3 points, can I get the radius?
4. I know BW can repeat geometry. However, I only see it can only repeat either on x or y. I don't know if it can repeat x and y at the same time.
Any input are appriciated
