Machine stops
8/12/19
John E
Website: http://mountainhomecabinetcompany.com
On our Biesse Rover24 It transfers STBIT1
to the spindle and then all is stopped.
Message: active slot with released cone
(1,in61) Also:End of program w/o TPO.
What could be wrong?
Thanks for any help, John
8/12/19       #2: Machine stops ...
Reads like there is perhaps not a tool position offset for the empty slot?
8/12/19       #3: Machine stops ...
John E
Mark, thanks for your response. My Machine guy is out of town. How do I check for the offset?
Thanks, John
8/13/19       #4: Machine stops ...
Mark T.
The sensor inside the router is not registering that the tool has been loaded into the spindle. Either the tool cone itself and/or the inside of the router have dust or debris build up to the point it is not seating properly ( clean both with denatured alcohol and a clean cloth - DO NOT blow air into the spindle!) or the sensors inside the router have failed or have came out of adjustment.
Hope this helps!
Mark T.
8/13/19       #5: Machine stops ...
Could be the fingers in the rack are out of spec and need to be adjusted as well.
I just had a tech fixing a different (operator induced) problem, but he didn't like how the tools were being dropped off and picked up, so he adjusted them.
I'm just throwing out ideas. I have zero Biesse experience.
8/13/19       #6: Machine stops ...
John E
Mark T.
You hit the nail on the head! It was packed with dried anti-seize. Our baby is cleaned up and running smooth!
Thank you very much, John
8/15/19       #7: Machine stops ...
Bob
I don't believe you should be using anti-seize. I can't remember the correct lube off the top of my head, but it wont dry out and clog like anti-seize.
8/15/19       #8: Machine stops ...
Mark T.
https://www.cnc-tool.com/cnc-greasemetaflux-lubricants.html
Lightly applied this is what you need.
