Options for drilling
8/26/19
John S.
We are looking for options to drill rows of holes in 4' X 8' X 3/4" panels. This will be the same basic pattern repeating over the entire panel. Which would be a better option, CNC router or multi-spindle boring machine? Any recommendations? Thanks!
8/26/19       #2: Options for drilling ...
Once or many times?
Hole spacing?
8/26/19       #3: Options for drilling ...
If you are only boring holes in panels that are already sized, go with the point to point style machine, they are cheaper. If you need to cut them to size, the router with a drill head will be your best option. From my experience, the routers generally have smaller boring heads, but the largest one I worked with on a router was a very big head. 15 in X 14 in Y on 32mm centers.
8/26/19       #4: Options for drilling ...
John S.
Dropout - many times. Probably 1-1/2 - 3" spacing. Thanks!
8/26/19       #5: Options for drilling ...
If it's many many sheets I would find an old light duty cnc or a cheap Chinese one and add some pneumatic drill heads to the Z axis spaced as you need them.
And scrap the machine when done.
It'd be a waste of a decent machine to drill holes all day every day and with that spacing you'd get no advantage from a drill block.
8/28/19       #7: Options for drilling ...
John S.
Thank you for the responses!
