CNC on Phase Converter
3/12/20
Jon Daniel Member
I'm looking into putting a Biesse on a phase converter at a shop with only single phase. I know the control needs to stay off the manufactured leg. Anyone have any experience in this?
3/12/20       #2: CNC on Phase Converter ...
ken petrunick
Website: http://kenpetrunickcustom.com
We run a phase convertor on our thermwood. Just a heads up make sure the converter is digital as opposed to a rotary converter. It was a $5000.00 lesson we learned the hard way.
3/12/20       #3: CNC on Phase Converter ...
Jon Daniel Member
What was the lesson?
3/13/20       #4: CNC on Phase Converter ...
Jim Anderson
Website: http://technocnc.com
Most machines (not all) only need the 3 phase power to run the spindle and vacuum pumps. the controller usually can be run off of single phase. The VFD (inverter) will take single phase power and output 3 Phase power to the spindle but at a reduced power level. A larger capacity VFD / inverter can compensate for the power loss.
3/16/20       #5: CNC on Phase Converter ...
Daniel Berlin Member
Rotary converters are okayish for motors, but really, you should not use them on electronics.
People do. Sometimes it works okay.
Sometimes it does not.
I wouldn't mess around with this. Just get a phase perfect and never worry about it.
3/16/20       #6: CNC on Phase Converter ...
Hey Jim,
They are not at a reduced power level.
In fact, most of them are 98+% efficient at conversion.
If you mean they output less three phase amps, that's just how AC works, it will output single phase amps / √3
The reason for larger inverter is not power loss.
It's because if you operate a 3 phase VFD on single phase, you need to derate the available output (due to DC bus ripple, heat, etc)
This increases the size of a needed VFD if you use single phase input.
Rule of thumb is that if you want to use a 3 phase VFD on single phase input, to use one with double the HP rating you need.
3/19/20       #7: CNC on Phase Converter ...
ken petrunick
Sorry for the late response but with the rotary converter the volt fluctuate up and down run 408 volts and when we checked the 3 legs they would vary from 320 volts to 440 volts. With the digital all 3 legs are the same voltage 412 volts. We went through 2 Siemans power units at $2200 apiece plus tech to install them.
    • Country Saw and Knife
    • Template Services
