Homemade vac pods... best material?
1/1/21
Steve Member
I'm looking to make some pods for my flat table. I've done some searching here but am still looking to find out the right material to use. I don't ever work with plastics so I am clueless on all the different types and a bit shocked by the price so I would like to get it right the first time.
Can anyone give me a recommendation on type on material and a supplier.
Happy New Year!
1/1/21       #2: Homemade vac pods... best material? ...
Gary R Balcom
If it's your first set, for occasional use, I don't think there would be anything wrong with using MDF, and a few layers of paint to seal it up. If you're building it for a lifetime of use, HDPE would probably be a good choice.
1/1/21       #3: Homemade vac pods... best material? ...
Steve Member
Thanks Gary, HDPE seems to be common and somewhat cheaper. I'm concerned about the slickness of it though, does it hold just as well as anything else? Am I over thinking this?
1/1/21       #4: Homemade vac pods... best material? ...
BH Davis  Member
Gray industrial PVC from McMaster-Carr or plain old white Azek or similar PVC. If for permanent use I'd probably go with the industrial stuff as it is much denser and ding resistant. For one offs I'd probably use scraps of 3/4" PVC sheet stock........Azek or any other brand. Done it both ways and both work.
Here is a photo of my home retirement CNC hold down system with a 3/4" PVC hold down grid as I was just finishing it up.
1/2/21       #5: Homemade vac pods... best material? ...
If you have a top shop around go and ask them for some solid surface drops. We make pods we are going to keep around out of it. Machines easy and durable. We are always drowning in small drops and scraps so its a handy use when needed. Most top shops have a lot of drops and sink cutouts that they may give away or sell to you for peanuts. You may have to invest in an epoxy gut If you need to seam for vacuum passages that are too deep to drill from the edge but pretty low cost to entry there.
1/2/21       #6: Homemade vac pods... best material? ...
Steve Member
These are some good ideas, thanks. I like the idea of solid surface drop but no one around here uses it.
1/2/21       #7: Homemade vac pods... best material? ...
BH Davis  Member
It took me a while to find these old photos.
These are the heavy density gray industrial PVC pods that I made back in about 2000. They are still in use in the business today. I must have made about a dozen of each size and 20+ years later they still work. A bit nicked up with some epoxy fill repairs but still functioning as intended.
View higher quality, full size image (786 X 502)
View higher quality, full size image (581 X 346)
View higher quality, full size image (542 X 350)
5/18/21       #8: Homemade vac pods... best material? ...
Salce Smith  Member
Hard PVC or bakelite are suitable material to make the vacuum pods. The CNC vacuum pods for Biesse Rover CNC are use this kind of material.
https://www.ricocnc.com/products/155-Flat-Grid-Table-Vacuum-Cups-for-Woodworking-Matrix-Table-CNC-Routers.html
7/21/22       #9: Homemade vac pods... best material? ...
Mike McClaran
Website: http://www.bettervacuumcups.com
All materials mentioned above will likely get the job done. These materials however are indeed slippery. When it comes to holding parts, BVC holds better than any other with patented designs and rubber specially formulated for a superior hold. For example this is our one inch cup with extremely fast feed speeds on a Biesse Rover. If you guys are having trouble holding smaller parts we can definitely help. 909 606-0140
https://www.youtube.com/watch?v=hjogY7oriZ4
    • Machinery Associates
