Need help with Bsolid
7/15/21
Kalvin Cackler Member
Website: http://woodhavencabinets.com
I could really use the help of someone who knows Bsolid. We are needing help tweaking a program we wrote to size our doors. There are still a couple of hiccups though:
#1: Have to manually change origin to 5 every time I run the program
#2: It does not cut the door on the 2 edges that are against my fence. Is there a way for it to trim 1mm off those 2 edges?
#3: I need the program to first back cut the two end grains about 3" to prevent blowout.
If there is anyone who is proficient with bsolid I would really really appreciate the help.
12/7/21       #2: Need help with Bsolid ...
big money
#1 are you having to change origins in the worklist? You can set the default origin in the program in the piece setting under the geometries tab and and it should save to that file. You can also set the origin in the tooling tab.
#2 I'm assuming that you are talking about the sides up against the stops? You can set up an x and y offset to clean up those edges by whatever amount by using the move piece function. You can also set these up as variables so you can adjust on the fly.
You can also do this with the blank piece option which is in the piece settings.
#3 not sure what you mean by backcut, do you mean like a scoring cut?
    • Machinery Associates
