Retrofit
1/20/23
Jim Anderson
I have an older CNC router that the control board has failed and the manufacturers upgrade price is too expensive (20K). I am looking for suggestions on aftermarket controllers to replace the original.
1/20/23       #2: Retrofit ...
You will need to provide more information about your machine for any detailed help.
1/20/23       #3: Retrofit ...
Jim Anderson
The machine is an older Multicam with a basic collet spindle, and stepper drives.
1/20/23       #4: Retrofit ...
You might try Gary Campbell at GCnC controls. He is a regular on Vectric's forum commenting on hardware control issues.
https://www.centroidcnc.com/cnc_retrofit.html
1/21/23       #5: Retrofit ...
james e mcgrew  Member
2nd on Gary Campbell, few do this as well as he does
1/21/23       #6: Retrofit ...
BH Davis  Member
Are you interested in building a new control yourself? It took a long time but I built a new control for my early 2000's Precix router. I used CNC4PC for the parts and guidance and UCCNC for the control software.
Other than learning how to tune the servos it was a pretty straight forward electronics project.
1/23/23       #7: Retrofit ...
What kind of control is it?
Try the used electronics market for a replacement board. It's amazing what you can find on ebay.
Depending on where you are a decent board level tech should be able to repair it. Look for the guys who repair fanuc controls and if they can't do it they may be able to point you somewhere.
    • Country Saw and Knife
