Best Cutter for fast feeds and rpm's
8/31/24
leonard cordaro Member
Our CNC router has a max RPM of 24,000 and not sure what the max RPM and feed rate should be for a high speed cutter for optimal cycle times.
I want to find out from experienced people who actually cut and get high feed rates and good finishes on their product. There are many cutting tools out there so finding a good combination is key.
Thanks all for contributing.
8/31/24       #2: Best Cutter for fast feeds and rpm' ...
First, is your machine heavy enough and rigid enough for high speed cutting. It does make a difference with finish quality. What brand and what weight? Max spindle speed is only part of the equation.
8/31/24       #3: Best Cutter for fast feeds and rpm' ...
Our machine weighs 7200 lbs - CNC Factory Router.
8/31/24       #4: Best Cutter for fast feeds and rpm' ...
That is on the light side. I would first try a 3 Flute compression tool at 24000 rpms at 1332ipm. If that is not a good cut, try 18000 rpm at 1000ipm. That would be the same chipload. but at lower feedrates. Beyond that, I would just dial down the feedrate until you get a good cut. BTW, this is based on melamine or mdf, plywood etc. that is 3/4" thick. Good luck.
9/3/24       #5: Best Cutter for fast feeds and rpm' ...
How much vacuum do you have?
What size table?
What size material?
What type material?
What dust collection?
What type of parts are you cutting? What's the smallest size?
Do you have a drill block?
Also, if you can find the acceleration rate that'll help. Don't forget that you need to go from 0 to full speed back to 0 again, and that's really tough in 12 inch long cuts.
All these are relevant.
As the previous poster mentioned, this is a light machine so don't expect super fast speeds. For reference, my 5X10 Komo is 16,000 pounds. We cut at 750 to 900 IPM. There are too many other things that affect this. Sheet to sheet time on a sheet of cabinet parts may be 8 minutes and moving from 750 IPM to 1200 IPM may cut the total time by 20 seconds or less.
9/4/24       #6: Best Cutter for fast feeds and rpm' ...
Oh, I forgot to mention. In order to save you money in tooling costs, just get a couple of tools from a vendor to see if you can approach 1000ipm. If you cannot do that with the new machine, do not waste money on 3 flute tools. Just dial in your feedrate based on the chipload you are trying to hit.
Chipload = Feed rate/(rpm * # of flutes)
Feed rate = rpm * # of flutes * chip load
Example my spindle hits max h.p. @16000 rpms. I don't want to lose to much h.p. at the top end speeds, but I want to go fast.
So, I will pick 18000 rpms with a 3 flute tool and hit a chip load of 0.0185 18000*3*0.0185 = 999ipm. So, with that tool my standard feed rate is 1000. This is how we go about thinking about this. Remember, a spindle has a power curve. at low rpms, the power drops off, same with high rpms. Ask your supplier to give you the power curve. They all have it. Helps you understand your machine.
9/4/24       #7: Best Cutter for fast feeds and rpm' ...
Mike McClaran
Website: http://www.bettervacuumcups.com
CNC Factory comes with an HSD spindle which in my opinion is the best. If you spin your HSD motor at around 16k rpm you will likely get more than a decade of life. Take here up to 24k rpm? I would then say 2 years of life. If you are worried about speed that much, buy a second router.
9/4/24       #8: Best Cutter for fast feeds and rpm' ...
HSD ES927L generates full 18.0 KW(24hp.) at 12000 rpm's. At 18000 its around 10 hp, so the drop off is significant. As long as you don't crash it, or do plunge cutting the spindle will last a long time.
11/12/24       #9: Best Cutter for fast feeds and rpm' ...
kingbreasts Member
Why are the speeds different on https://en.wikipedia.org/wiki/Speeds_and_feeds?
    • Machinery Associates
