Wood to Metal
11/17/24
Okay, looks like I am getting involved with a 5 axis machine made for metal with a customer of mine. Been doing wood for 30 years. I have no experience cutting ferrous material. Is there any places that I can get good info on chipload, feeds and speeds for cutting metal? Thanks. This is a flood machine, so there will be cutting fluids.
11/17/24       #2: Wood to Metal ...
RocketDC
I use the FSWizard app, it's awesome.
11/18/24       #3: Wood to Metal ...
Cnc zone has a very active forum segregated into machine specific threads. Try there.
https://www.cnczone.com/forums/
11/21/24       #4: Wood to Metal ...
NeonVortex Member
This website provides data on chip load, feed rates, and speeds for cutting different metals.
https://www.want.net/feed-rate-and-cutting-speed-whats-the-difference-in-cnc-machining/
12/10/24       #5: Wood to Metal ...
Brooke Member
Not sure if this type counts?
https://www.want.net/how-to-prevent-galling-metal-in-cnc-machining/
1/9/25       #6: Wood to Metal ...
Mark Tomlin
Whomever the tooling vendor is for the shop is going to be your best resource.- multitudes or more brands of tooling on the metals side and shops tend to be brand loyal ib that arena. Also tolling is ALOT more set up specific in regards to strength, rigidity and harmonics ( if your not familiar with chatter you will be)
    • Machinery Associates
