Omnitec Selexx Eco overtravel error
1/15/26
Steve Waldner Member
My cnc has an +Z overtravel error but is nowhere near the overtravel limit. Is there any way to reset the limit.
1/16/26       #2: Omnitec Selexx Eco overtravel error ...
If the machine is nowhere near the limit, I would check the proximity sensor first. They do go bad. Not really sure how those machines home. I have physically moved the sensors on some machines to get what I need to run. You could call support to get some advice.
1/19/26       #3: Omnitec Selexx Eco overtravel error ...
Alex_Zhang Member
Mike is spot on about the sensor.
Since this is a router, before replacing the sensor, just double-check for packed wood dust or chips between the sensor face and the flag. I've seen fine dust bridge that gap and trigger a false positive on capacitive sensors.
Also, regarding 'resetting' it: If the sensor is clean but the controller still thinks it's tripped, it might be a broken wire. Most limit circuits are wired 'Normally Closed' (NC) for safety—so if a wire breaks or vibrates loose, the machine defaults to the 'Overtravel' state to be safe.
To move it, look for an 'OT Release' or 'Limit Override' button on your control panel. Usually, you have to hold that button down simultaneously while jogging the Z-axis in the negative direction to clear the latch.
1/19/26       #4: Omnitec Selexx Eco overtravel error ...
Got it fixed. Had nothing to do with sensor. Was a memory thing. Machine remembered that spot and had to be reset. Hold down "p" and "cancel" while powering up reset memory. Then I homed it and was good to go. But, anyway guys, thanks for responding.
1/20/26       #5: Omnitec Selexx Eco overtravel error ...
Alex_Zhang Member
Glad you got it sorted, Steve!
That P + CAN (P + Cancel) startup is the classic Fanuc trick. It tells the controller to ignore the stored Soft Limits (software boundaries) during boot-up so you can move the axis back and re-home it.
I assumed it was hitting a hard hardware switch, but it turns out it was just the software brain getting confused. Thanks for posting the solution—that will definitely save someone else a service call down the road.
    • Machinery Associates
