Subject: HOMAG BOF 211/30/R – Intermittent Mid-Program Stop / Spindle Safet
5/16/26
Victor Adams
Website: http://www.solidworxusa.com
Machine stops randomly mid-program with a spindle safety protocol fault. No consistent pattern — sometimes it completes a full program, sometimes it stops partway through. Never the same spot. Restart and it may finish or fault again.
Spent approximately $25,000 in parts replacing what the manufacturer’s service company recommended. Problem was never witnessed live by a technician — diagnosis was done remotely and by description only. Parts did not fix the issue.
Machine mechanicals are solid. This is a heavy-duty production machine and worth fixing if the fault can be properly diagnosed.
Not looking for Stiles. Looking for someone who has actually worked inside HOMAG controls and can come on-site in Southwest Florida, or who can point me toward someone who can.
If you’ve seen this before or know who to call, please reply or DM.
5/17/26       #2: Subject: HOMAG BOF 211/30/R – Inter ...
Jim Anderson
Website: http://mullismachinery.com
Victor,
I have worked on many different machines over the years. Intermittent / random issues like what you have described are 99% of the time, Electrical in nature such as a lose or shorting wire that randomly creates the issue. Unfortunately many inexperienced techs will throw parts at the problem hoping that something works. When I was young working with my father at his shop, he told me "any monkey can swap out parts and get lucky once in a while, but it takes a trained technical person to understand why the problem exists".
I have not worked on a HOMAG, but all of the machines work Check all your wiring connections. Start at the incoming power and work your way out from there. Just because it is a spindle related issue doesn't mean the problem isn't elsewhere in the line. A loose incoming power line can manifest as an intermittent dropped leg.
5/17/26       #3: Subject: HOMAG BOF 211/30/R – Inter ...
Allen Chalifoux
Can't help if it's a machine problem but I can attest to the dropped leg .
We have a vacation home in N.Ft Myers ( my shop is in massachusetts) .
After a year of replacing appliances including the heat pump in contacted LECO and they replaced the service entrance cable. Problem solved.
The linemen told me that it's a common problem.
I realize I'm comparing single phase service to 3 phase but it's still something to look at.
Good luck, Allen
    • Country Saw and Knife
