Suggested Anderson Selexx Wall Clearance
3/24/26
Gabe Member
Howdy,
I am new into CNC work and have gotten an Anderson Selexx 510.
Per the manual I need 5ft of clearance around the machine.
I have some space in my work to accommodate that, however, is pushes other machines out of the way.
Can anyone tell me what they have found to be a safe minimum for their shop?
Cheers,
Gabe
3/25/26       #2: Suggested Anderson Selexx Wall Clea ...
Gary
The main part of our Selexx is 4ft from the wall. That gives us 1ft clearance for the overhanging tool carousel to the wall. The other side and ends of the machine have more than 5ft. because it just worked out that way.
5/24/26       #3: Suggested Anderson Selexx Wall Clea ...
Brian
Do not short yourself on space. I'm running a Selexx 510 FL with 4 bay MLS and have found the biggest issue is not enough space for the output. Major underthinking as to where the machine was set.
    • Country Saw and Knife
