CUT RAW VENEER TO SIZE
6/9/26
JOHN ALLAN Member
Website: http://arkansawooddoors.com
We mfg veneer raised panels for cabinet doors. Past years we cut our veneer to size manually using large paper cutters. Due to loss of my veneer face supplier we are forced to purchase our veneer a 48" x 55" size faces. My plan is to cut our veneer faces to size on our 4X8 Thermwood, using our nesting software. Plan is to use 1/16" down shear bit, veneer held in place on spoil board with our vacuum system.
Anyone had experience doing this, suggestions welcome.
6/9/26       #2: CUT RAW VENEER TO SIZE ...
Do you have a C axis on your main spindle? I have used these type of aggregates for demos on stuff like that. Don't own one, but from the demos I've done, they work very well. Careful handling the zero kerf knives. I've spilled a lot of blood!
https://www.youtube.com/watch?v=z4O3vRCrRm0
6/9/26       #3: CUT RAW VENEER TO SIZE ...
Oh, I like the Techniks(Atemag) better than the Benz. The Benz unit I got was not new, but it leaked oil.
6/10/26       #4: CUT RAW VENEER TO SIZE ...
jerry Member
I would try a drag knife
6/10/26       #5: CUT RAW VENEER TO SIZE ...
I have used drag knives for demos too. Work pretty well, but you need software to get a toolpath. I needed to use Aspire, since Alphacam doesn't support it.
https://www.youtube.com/watch?v=jHcPQXw5cKA
6/11/26       #6: CUT RAW VENEER TO SIZE ...
David
Where are you located? Could you find another supplier?
    • Country Saw and Knife
    • Limtech Industries, Inc.
