Dialing in feed rates vs. edge quality on 3/4" pre-fin maple
11/7/26
Zev Sterling Member
Website: https://remodeloscabinet.blogspot.com/?m=1
Running a decent volume of 3/4" pre-finished maple and multi-ply birch plywood for cabinet boxes and drawer components. We're currently running standard 3/8" two-flute compression spirals, but looking to optimize between edge chippage on the top veneer and overall tool life when pushing feed speeds.
For those running nested base setups daily:
What spindle speed/feed rate combinations are giving you the best balance between clean top veneers and decent tool life before dulling?
Are you running a roughing pass leaving an onion skin followed by a clean full-depth cleanup pass, or going single-pass at high feed?
Appreciate any insights or real-world numbers from your shop floor.
11/8/26       #2: Dialing in feed rates vs. edge qual ...
Rob Young Member
Zev,
I am assuming you are using a chipload chart to set up your initial feed rates. Keep a couple of things in mind.
1. if you are through cutting 3/4 inch material with a 3/8 tool you need to reduce the feed speed by at least 25%. If using a 1/2 inch tool on the same through cut you need to reduce by 15% to allow clearing of the chips.
2. Not all machines can efficiently cut at the advertised linear cutting speeds. Acceleration and deceleration really help determine this and often manufacturers rate their linear cutting speeds higher than they should considering almost all parts require slowing down and speeding up at least four times when cutting out a rectangle. You will overheat the tool if the acceleration and deceleration speeds are to slow for the the programmed linear cutting speed. This was a determining factor when we set the linear cutting speeds for the machines we offer to our customers.
https://nutekmachinery.com
