Holz-Her Lynx 7511 - angle head / 6 mm drill / 12 mm collet?
11/18/26
Amir
We run a Holz-Her Lynx 7511 (HOPS, HSK-F63 main spindle, DH 7879 drill block, vertical drilling only). Questions for other Lynx owners:
1) Can the main spindle take an angle head (aggregate) for edge drilling or grooving? Is the pin ring around the spindle the stop for such a head?
2) Can an empty spot on the drill block take a 6 mm bit?
3) Has anyone fitted a 12 mm collet on this machine?
Thanks.
11/19/26       #2: Holz-Her Lynx 7511 - angle head / 6 ...
I am not familiar with Holz-Her machines, but typically the ring around a spindle would be an aggregate torque arm retainer. With an adjustable angle aggregate you can drill at angles. I don't use drills though I drill with upshear router bits. You can groove using the same aggregate with a saw blade and any angle, horizontal, or vertical and any angle in between. On the 6mm drills, you can buy them from about any tooling company that has the 10mm shank for the boring head. They typically come in 57 or 70mm overall lengths. Aggregates open up a lot of possibilities, but need to be used with care after training.
11/19/26       #3: Holz-Her Lynx 7511 - angle head / 6 ...
Amir,
Here is a video of the angled drilling that I think you are asking about.
11/19/26       #4: Holz-Her Lynx 7511 - angle head / 6 ...
That did not work. Try this.
https://www.youtube.com/watch?v=k6g_bYxJqAQ
    • Country Saw and Knife
