Dust Collection
Subject: Re: How do you heat only part of a medium-size wood products factory building?
2/4/13
swisswood Member
We have a wood products manufacturing business in a 20,000sf tall-ceiling steel building. The particular focus of our process only requires that craftwork take place in about 4000sf of floorspace so we are reticent to heat the entire building. Our unique problem is that we work regularly with edge-glued wood panels, and while the building is equipped with ceiling-mounted Radiant Heat units, we have been warned against using these as they will cause our edge-glued panles to cup. We have an extensive inventory so can't risk that.
What has worked for others? Because we are in the South, our winter season is relatively short and so I'd rather not spend enormous sums, but I need to do something, for plant morale as much as anything. Are there portable heaters that aren't too much of a fire risk?
On a related note, we would also like to reduce the overall ambient humidity.
I should state that we don't use catalyzed finishes.
2/7/13       #2: How do you heat only part of a medi ...
mike
could you use plastic strip curtains or insulated warehouse curtains? does not help the height siyuation but you can block off heat to certain area,s and still easily access the area.
2/24/13       #4: How do you heat only part of a medi ...
Michael Sanders  Member
radiant heat.
