Dust Collection
Subject: Re: Fire Code Violation - HELP
8/8/18
Mike Hoffer  Member
Website: http://www.carolinaclosetsplus.com
can anyone tell me what size the dust particles are for cutting melamine on a cnc router? i need a general idea. i know it depends on speed and feed but i've been hit with a fire code violation that will require me to separate my space with fire walls.
The rule is 420 microns or less requires a fire wall. can anyone tell me how big that is? i need some technical date to provide.
We are shut down until i can fix this. Please help if you have anywhere i can turn. Thanks.
8/9/18       #2: Fire Code Violation - HELP ...
David R Sochar  Member
0.0165354331" = 420 microns
1/64" = 0.015625"
That is about as much help as I can be. You can hire a lawyer and get a court order to allow you 30 days or similar to implement a solution. Especially if you have employees.
What is coming off your bits, I don't know. The Partical Board lobbyists will know what your equipment is likely to produce and may have some ammo to help you fight.
8/9/18       #3: Fire Code Violation - HELP ...
Mike Hoffer  Member
thanks for the help.
8/31/18       #4: Fire Code Violation - HELP ...
I'm sure that routing most any board is going to produce some dust finer than 420 microns. So no matter how it's measured they've got you!
